The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Preguntas 253 Ver todo
MacBook Air 2015 Screwdrivers
Welcome,
I recently wanted to clean up my Air. I bought a Power 8800c screwdriver - star 1.2x50mm star. Unfortunately, I unscrewed a little and this screwdriver didn't fit.
I don't want to buy the same thing twice, so my question is - what more does a screwdriver need? Are P5 Pentalobe or T5 Torx or Phillips #00 the ones I have? Or maybe I still need the TR8 Torx to dismantle everything?
Thank you in advance for your reply.
Greetings
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
1 Respuesta
Solución Elegida
Hi @giorge ,
You will mostly need the P5 Pentalobe and the T5 Torx.
The display hinges will need the T8 Torx.
The trackpad will need a Phillips #00.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Hey, great thanks.
In this case I already have P5 Pentalobe (1.2 mm) and don't need P5 with other dimensions (e.g. 0.8 mm)?
por
That is correct. By the way, P5 should only come in 1.2 mm. 0.8 mm pentalobe would be a P2, and 1.5 mm would be a P6.
por
Añadir tu respuesta
Gorgio Antonio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 46
