Saltar al contenido principal
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Preguntas 30 Ver todo
The controller and the drone unit will not connect?
Batteries are charged on drone and remote batteries are new. Had a problem with a wire coming loose from the pc board that connected a motor. I repaired that and checked the motor before closing up the unit. Drone functioned perfectly. I closed up the unit and now the controller and the drone will not connect. I have followed the suggested procedure for connecting the unit before flight and still nothing. This is a sharper image dx-2 stunt drone Any idea what could be wrong?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
14 comentarios
I have no clue how to use this site and cant seen to find answers. I have a no connect problen with same dx2. Can anyone help
- de
Same problem here.
- de
and here... same problem dx 2 remote will not pair ... just flashes
- de
Same here I bought my son the dro 004 any ideas
- de
Completely charge both,turn kn dx2 then switch your remote on move the left analog stick from down, up, and then back down it should beep then the lights will stay steady
- de
Mostrar 9 comentarios más
Agregar un comentario
12 Respuestas
Respuesta Más Útil
Did u by chamce accidentally knock the antenna from its connection to the pcs wben u closed it back up? Im not sure brother, but this is the first thing coming to mind after seeing u fixed the prop disconnection issue (oddly enough, my wife bought me a dx-2 and I had a motor wire snapped in half by sharper image attatching the top and bottom casing together and catching it/cutting it in half) u in eastern kentucky by chance? Lol. Cauze i returned it to walmart when my splicing job didnt hold well during
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
I am in central ky. ( Berea ) have not repaired anything on the drone, took it up for a test flight turned it off and recharged it, and now the remote will not pair it just flashes... any thoughts... ???
- de
This is the exact same thing that we did! We used it, it was fine, then we charged it, shut both things off.. and just went to use it and it won’t pair! How annoying! My brother is a mechanical engineer and he’s opening it up right now to see what’s wrong!
- de
Mine is doing the same thing wtf
- de
Had a previous drone, flew away, bought a new one and now it won't pair
- de
My 2 cents….
Somehow, it's possible the crystal on your fc when batty… don't ask how, why or whatever…. Change the crystal on fc. That should hopefully fix your pairing problem.
But! Make sure you replace it with the same value crystal.
Anytime I've gotten some stupid idea to drop $20 on a toy quad, it never fails… I always end having to replace crystal with new. Smh.
Helpful friendly advise…
Save up just a little more money… get you an entry-level name brand RTF kit for like nada to really get you in the right direction.
From there… the sky is literally the limit.
Good luck.
Have fun!
Puntuación 1
1 comentario:
Its 2.4 gig and does not have replaceable crystal.
- de
I have charged the drone. But the remote control will not fly it. Meaning… the red button won’t pop up when I switch it to on and when I try to use it…it will not fly..,any suggestions ?
Puntuación 1
1 comentario:
Do you mean the red light? On the remote or quad? If one or both wont light the batterys dead in remote or not charged in drone. If batteries are good then problem could be internal damage.
- de
Hi, I was having the same problem with my dx-2 I took a part the remote and everything was fine, but still with the problem of not connection, but did like a external push ( hit the each blade with your finger to make it rotate)to the dx2 blade when still on with the controller on also,and it work my dx2 is flaying again.
Remember hit as you hit a marble but softly and trying the controller to mait flaying .
P.S. recharge the drone to get a full battery power.
Good lock
Androi48.
Puntuación 0
1 comentario:
What do i do, my dx-2 drone is on the “on” mode and its not turning on but the remote is on what do i do?
- de
Can i fly my DX-2 drone without a controler. Can i just use my andiod phone
Puntuación 0
In order to fly the drones, all you need to do is simply download the android mobile phone app and sync it with the drone and you are set. ... The best thing about this particular drone is that it can be easily controlled by either the android app or the remote controller, which makes it a flexible choice.
Try 360 flight app in android play store
Puntuación 0
the other 2 wouldn’t fly and the others could it’s not flying
Puntuación 0
No all Android smartphone wotk with using your phone as remote controller.
Some of this drones work with Bluetooth signal others with wifi.
If you have an android phone or iPhone make sure the your phone model work with the type of drone you have.
Puntuación 0
1 comentario:
I have the same problem, all like you new sound controller battery and the drone and fully charged. Except me, when I start the drone and the controller, both start, but the lights of the drone as well as the controllers start to flash and do not connect. What should I do?
- de
Puntuación 0
I don’t Know but try rebooting it and if not, try taking it to I.T or go to a nearby company that has drones. Otherwise, that’s all I have for you.
Update (02/10/2021)
Yeah so thats all. I have nothing else for you sorry.
Puntuación 0
So if this helps anyone with their problems of the drone no connecting turn both the controls and the drone and click the stun button like 5 to 10 times fast and it should pair the drone that’s what I did with mine and it worked hopefully it works for anyone looking for answers!
Puntuación 0
because the energy is not to powerful that mean the drone c ant connect easily
Puntuación 0
Añadir tu respuesta
Ben Taylor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 55
Ultimos 30 días: 325
Todo El Tiempo: 18,434
