Power lock don't work
Back passenger driverside door the lock won't lock or unlock with the power switch I have to manually do it what do I do to fixed it
Es esta una buena pregunta?
Hi @towman412 ,
You need to check if there is power getting to the door lock actuator when you operate the power switch.
If there is then whether the actuator motor is OK and if it is if there is a bad earth connection to the actuator.
Here’s a video that shows how to replace the actuator in your vehicle, which may be of some help.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 158
