Saltar al contenido principal
Modelo de mediados de 2012, procesador A1278 / i5 a 2,5 GHz o i7 a 2,9 GHz.
Preguntas 1622 Ver todo
when my MacBook Pro is off it charge to orange
I received this system from a customer. It seems that it’s OK (except its really slow).
I tried SMC to check if it would charge when its on, but doesn’t work but, when its off the mac, the LED goes Amber right now, it’s been like 10 minutes since I shut it down, I’m gonna wait if it goes beyond the 2%
What software recommend to check the health of the battery, according to the system report it says "its fine"
Update (07/14/2018)
So I replaced the battery with another MacBook that I have and I notice it’s not charging either, it says that the battery is not charging, is depending on the charger? Also I tried with the other charger and it says the same message, and I realized that the other system is working fine with this battery, I can’t say it needs a battery if I can’t charge the battery.
Update while writing,
I downloaded TG Pro and the systems readings are OK.
The only thing that I have to check is the MagSafe port if I have to replace it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This is probably the best App for Mac: https://www.coconut-flavour.com/coconutb...
Fue útil esta respuesta?
Puntuación 1
1 comentario:
im updating this mac it has an older yosemit version, but it ask me to updgre to mac high sierra to use it, and its all crazy
- de
If the system is really slow it’s likely in SafeMode as one of the thermal sensors is telling SMC the system is overheating or the sensor is missing.
The easiest way here to check is to run this app: TG Pro paste a screenshot of the main window (You’ll likely need to stretch the window a bit so all the sensors show up) here for us to see Agregar imágenes a una pregunta existente
Update (07/15/2018)
It does sound like your DC-In Board needs to be checked. Review this Apple T/N to make sure your using the correct charger and as a reference on what the MagSafe connections look like: Apple Portables: Troubleshooting MagSafe adapters.
Here's the IFIXIT guide to replace the DC-In Board: Reemplazo de la Placa de Entrada de CC MagSafe del MacBook Pro 13" Unibody Mid 2012
Its also possible the charging logic on the main board needs repairs.
Did you get CoconutBattery working? That might offer a clue here.
Imagen de MacBook Pro 13" Unibody Mid 2012 Placa de Entrada de CC MagSafe
Guía
Dificultad:
Difícil
45 minutes - 1 hour
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Puntuación 1
3 comentarios:
im goning to try to install it it has an older version of yosemite, i hope that site has an older version of that app
- de
I swapped the DC in board with the other macbook pro and the problem continues, I'm guessing is in the logic board, I have 2 mag safes from 2012 and another one from a macbook 2010 15"
- de
What does CoconutBattery show you?
- de
Añadir tu respuesta
armandomh91 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 42
