Saltar al contenido principal
Pantalla de 27" con resolución de 2560 x 1440 píxeles Conexiones de cable Thunderbolt y MagSafe
Preguntas 160 Ver todo
Apple Thunderbolt display isn`t working
My monitor does not turn on, I took it to an authorized apple service center and they told me they had to change the power source (sounds logical) but they added the change of "rear housing" which is a very very expensive piece, (it doesn't sounds so logical to me) they explained that the On/off switch is embedded to the housing, I don't repaired it whit them, I purchased an power source on eBay and I changed it my self, but it just doesn't turn on... How I could get it fix it without having to expend so much money?... It could be the EMI filter?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sounds like they don’t really know the issue at all as they are telling you different stories here.
While not easy you can repair the power switch if that is truly the issue. But the power supply is a sub assembly internal of your system and can be replaced on its own. Which sounds like what you did.
But lets go back to your original power supply and really do the proper diagnostics to isolate out what is the problem as your just following what the person who gave you the story told you.
Plug in the AC power and if you have a MacBook Pro, plug in your system to the MagSafe connector what is the color of the MagSafe Plug Free or Amber or nothing?
If you don’t have a MacBook Pro to test this can you give us a bit more here when you press the power button do you hear a fan running? Do you see any flicker of light from the display?
When you connect your system with the display cable and go into the display control panel does the display show up? If it does take a flashlight and rest it on the displays glass at a sharp angle (15 or so degrees up) do you see a faint image of your desktop and its icons?
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
merelo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 295
