What’s up with my Joy-con calibration?
The calibration on my right Joy-con on my switch is broken.Does anybody know how to fix it?
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 67
Can you give more details on your issue? I recently had a problem with my left Joy-Con, which would "drift", ie. would move upwards by its own and would not return/stay in its default, central position when untouched. Is this the issue you are experiencing?
- de Louis
If this isn’t a hardware problem. Then going to settings scrolling down to controllers and sensors. Then clicking on calibrate control stick select the stick you want to calibrate. And click y to go back to default settings. that should fix the problem
- de Chase
