Why my phone isn't charging?
my phone charging port is broken every time i charge my phone it lights up but its not charging and i need to know if it can but replaced.
Es esta una buena pregunta?
Please be advised that you will need to remove the screen to do this . Take your time aplply heat to the screen with a hot air gun to loosen the glue holding it shut. You will also have to solder the new port to the board . This video shows the whole process https://www.youtube.com/watch?v=76QIweFh...
This person used kapton tape to isolate the area around the port so he could desolder using a heat gun . this was not really show well in the video . Kapton tape disperses heat so only the area you want heated gets heated. Hope this helps
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 245
