Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Battery burst into flames after removal!
The attached photos, ( if you can see them) show the destructive power stored in an iPhone 6 battery with approx 70% charge on it. After removing it from the phone, I was straightening it back out, when suddenly it started to flare up ! I had to throw it, it bounced off a door and onto the floor where it continued to burn intensely like a signal flare for what seamed like a 10 seconds or so. This would have destroyed the phone had it gone off while removing it, or seriously burnt my hand for sure in a split second ! Set off the smoke detector, filled the shop with soot and fumes, smelt like a welding shop after, just want to say be very careful with these, I have probably swapped out 100 or more batteries over the last 4 years and never had one go off , now I have a metal can full of water right beside me when doing any iPhone battery swap.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Over stressing the battery in the removal process often leads to a failed battery (one of the reasons glued batteries is such a bad idea). Most of the time it just takes a small puncture to set things off.
You’re lucky! It could have been worse!
Fue útil esta respuesta?
Puntuación 2
Did you use metal prying tools or any sharp tools to remove the battery? This should never be done. It's better to use plastic playing cards / flexible cards and some ethanol / isopropyl alcohol instead.
Also don't bend the batteries or pry at them too much it'll puncture the battery.
Puntuación 2
Añadir tu respuesta
Steve Adams estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 106
