Saltar al contenido principal
Lanzada el 28 de julio de 2017, la New Nintendo 2DS XL es una consola de juegos portátil que sucede a la Nintendo 2DS.
Preguntas 204 Ver todo
Won’t turn on anymore
Well long story short my child was playing his 2ds xl and dropped it from about a foot and a half to the ground and since then I can’t get it to turn on anymore. The only thing it will do is the blue light comes on and after about 5 seconds or so you hear a popping noise from the speakers and it powers back off, the screen never lights up or anything. I’ve looked up as much as could find on these new 2 ds xls and have taken both covers off and tried to unplug and plug back in every ribbon cable I could see as well as tried to see if anything else looks damaged and can find nothing. Is there anything else I could try or has anyone else had this problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Try opening it at around 40°. If it turns on turn the brightness down to 1... or check the connection for the top screen
Fue útil esta respuesta?
Puntuación 0
It is most likely related to the screen ribbon cables. More specifically I had the exact same issue with the lower screen lcd backlight ribbon cable not making contact with the motherboard. I pushed it back in and it worked fine after that. The ribbon cable is the 4 pin cable right above the circle stick ribbon cable.
Puntuación 0
Añadir tu respuesta
Chris Rose estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 171
