Solder lightning connector car charger
is it possible to weld the lightning connector of the following charger for iphone 5?
Es esta una buena pregunta?
Hi @piero90
WARNING, please do not directly solder and use it.
Cigarette adapter in cars output mostly is 12V
https://www.nonda.co/blogs/news/13486157...
USB uses 5V.... direct 12V can kill your devices
If you see the USB 2.0 wire layout.... there are four cables vcc, d-, d+, gnd
https://www.chipworks.com/about-chipwork...
I would suggest you to get a cigarette adapter to USB charger as it has been converted to 5V and USB standards. You only need to get MFI certified lightning cables to charge your apple devices.
is it possible to reconnect the cable to the lightning connector that has come off?
Comentarios:
Hi @piero90
Give you an idea what is inside,
https://www.youtube.com/watch?v=kjEBbGWg...
but as commented earlier, do not connect or solder it directly to use in direct to the cigarette adapter.
- de Augustine
How can I fix it?
- de Piero Sabino
https://thewirecutter.com/reviews/best-u...
Get this and put in your car, get a new USB lighting cable.
- de Augustine
So I can’t repair it.
- de Piero Sabino
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 617
