Saltar al contenido principal
Número de modelo NV370. Tiene una altura de 27 pulgadas y cuenta con la tecnología de succión y dirección giratoria de Shark.
Preguntas 27 Ver todo
Why is my brush roll and indicator not working?
My indicator light stays off and the brush roll doesn't function. I removed the roll and disassembled it. No blockages, everything clean, wires are good, position switch working properly. Performed wiring checks, beyond possible high resistance through the circuit board no issues noted. Can find no information on how much voltage should be being supplied to the brush roll. Or what proper resistance readings should be. Checked voltage at where the brush roll connects to the base. Vacuum on 7V with or without pressing the latch switch to imitate the bottom being connected unsure what proper voltage should be.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Hi there ,
I recommend calling the manufacturer for support as they have their engineers who designed them and who can help you on the phone line
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Roller not turning,no green light checked no plugs,filters ok
- de
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
Puntuación 0
Remember, the handle must be pulled back for the roller brush to turn on AND the switch must be set to carpet or the 2nd position on the switch. Green light should come on.
Puntuación 0
Remember, the handle must be pulled back for the roller brush to turn on AND the power switch must be set to carpet. The green light should turn on.
Puntuación 0
Añadir tu respuesta
devstamant estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 24
Ultimos 7 días: 164
Ultimos 30 días: 770
Todo El Tiempo: 7,435
