Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una cámara digital de apuntar y disparar de Panasonic identificable en América del Norte por el número de modelo DMC-ZS7
Rear screen is broken.
There is a 'spiders' web' smash-mark covering the entire screen radiating from a central point, as though it has been hit by a sharp point. Although functions such as zoom still work, there is nothing usefully visible on screen, either in Camera or Review mode, except a narrow strip down the left-hand side.
How can I replace the screen, and how do I purchase one (in the UK)?.
Thanks,
Alan H
Es esta una buena pregunta?
Puntuación -1
1 comentario
alan there are loads of these on ebay uk currently, I was searching for a different screen... I also found them on alibaba, you may also see that the vendors may list DMC TZ but not the no. you want... keep reading the description and you'll find some are compatible between versions. then you can go back to ebay or use alibaba (which you may have to wait for from hongkong/china or buy more than one, you'll need to negotiate)
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Alan, there are just to many steps in telling you how to disassemble your camera. I posted the service manual for you on my file server right here I hope this will help with the replacement. As in where to buy a replacement, I have had poor luck in finding the LCD. There is only one place that I found right here Price is a little steep but it looks like a really nice LCD. Good Luck to you and I hope this helps in getting your camera fixed.
Fue útil esta respuesta?
Puntuación 1
Thank you both for your help, and apologies for not responding to Old Turkey ( :-) )sooner, due to absence.
Will have a crack at it if I can source a suitably-priced LCD.
Alan H
Puntuación 0
1 comentario:
You'll get it done...;-) I keep my eyes and ears open for an LCD and will let you know if I dig something up. I was just making sure you got the manual before I remove it from the server to make room for more stuff:-) do not hesitate to let us know if you need some further help, good luck.
- de
I too have a similar problem do you know where I can buy the service manual for the TZ10 as it disentangle seem to be on panasonics website
Puntuación 0
Añadir tu respuesta
Alan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 4,155
