Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2362 Ver todo
Pregunta Cerrada
White Conversion Proximity Sensor on 4.2.1. not working - Help
I've tried the fix in "Proximity Sensor Reversed Somehow" but i still can't get the sensor to work.
Does anyone have a step by step or better pictures?
This seems to be on the new iphones that have the pentalobe screws and are 4.2.1 or newer, below 4.2.1 the black marker over the sensor holes fixed it.
http://guide-images.ifixit.net/igi/3lwdx...
This is a picture from the question in bold above, but although i've tried using black electrical tape and making 2 small holes over the sensors, i can't get it to work.... can anyone help?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Here is the best iPhone 4 proximity fix sticker I have found. This will fix it. Here is where you can get it. Read the reviews. I have used it on 50 phones so far with just 2 that it didn't fix, and those 2 were already janky in the first place so......
http://www.ebay.com/itm/250888416604
Fue útil esta respuesta?
Puntuación 0
Hi
I'am iPhone Repair Technician 1 year experience, repair daylig between 2-6 iPhone's.
Here a solution that works, you can use electrical BLACK tape, it must be black color, cut 2 pieces and put them together, then cut 2 very small holes, place it above the proximity sensor.
You can watch this video tutorial about the electrical BLACK tape:
http://www.youtube.com/watch?v=EX9oMrHb1...
To see where the proximity sensor, watch this video:
http://www.youtube.com/watch?v=pTVPrxkNW...
Puntuación 0
Second link that Alawi sent is the fix I use all the time and it works 90% of the time.
if this dont work try putting a tiny strip of foam btw the proximity sensors.
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,828
