How do I remove the front panel on the HP OfficeJet 7500A printer?
My printer is not picking up paper. I have cleaned the rollers and manged to remove the left side panel. However it does not recognize the fact that there is good quality (not curled, not wrinkled, etc.) paper in the printer. It has been making ratcheting noises for several months, has finally stopped lifting up paper all together, although it sounds as though the rollers are still working. I have the left side panel removed but can't find the clips that secure the front panel. Any and all suggestions will be appreciated. Thank you! ANSWER: I've not received an answer on removing the panel, but I have confirmation the gears are broken & replacements are not available. Hence this scanner/printer is heading for the scrap heap.
Es esta una buena pregunta?
