Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Guías de reparación y desmontaje para equipos de escritorio fabricados por Acer.
Preguntas 51 Ver todo
Windows 7 reset password/log in
I forgot the Windows 7 log in password to my Aspire AM3900G. How do I override it with out the reset disk?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Use laze soft password recovery, this tool won't give you your old password, however, it will completely remove the password, allowing you to create another one. All you need is a USB flash drive with the software installed, then boot up off of the USB from the boot menu on your computer.
Download
Fue útil esta respuesta?
Puntuación 0
you can reset Windows 7 password with '''++Chntpw++'''.
It will be a little complicated. And also, you can use the professional tool like iSunshare Windows Password Genius. It can help you to create a recovery disk on any other accessible computer . Then you can reset Windows 7 password easily. But it will not help you find back the previous password.
Puntuación 0
Hello,
Firstly, you can try to boot Windows 7 in Safe Mode. When the login screen appears, if there is an administrator account is displayed beside your admin account, click it to sign in without password. So you can reset any other user account password in control panel after logging. Steps can be found here: Reset Acer Latop Password Windows 7 in Safe Mode.
If you cannot log on Windows 7 via Safe Mode, you can use a Windows 7 install disk to copy cmd.exe and rename it to sethc.exe, then open it from Windows 7 login screen. So you can reset Windows 7 password by using command line.
Puntuación 0
Añadir tu respuesta
Andy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 168
