Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 4.7" es la versión más pequeña del iPhone 6 Plus. Identificable por los números de modelo A1549, A1586 y A1589.
Preguntas 5139 Ver todo
Not able to restore
I have an old iPhone 6, I have recently tried restoring it to factory settings but no luck. I’ve tried through the phone and connecting it to iTunes.. nothing worked. Currently it’s stuck in recovery mode and I can seem to get it out of it. I’ve tried everything I know. It was thrown at a wall once so maybe a component inside is damaged? Error 56 problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Have you tried using "3uTools?"
I had the same problem.
1.Download 3uTools
2.Install it(Obviously)
3.After Installation connect your IPhone in Recovery mode
4. In 3uTools select the option called "Flash & JB"
5.Select the option called "Easy Flash"
6. And after that you will see a list of available IOS versions for your IPhone.
7. Untick the option called "Retain User’s Data While Flashing" Beside Flash
8.Just tick the Circle of the version of IOS you prefer and click "Flash"
If not, try visiting your local apple store
Fue útil esta respuesta?
Puntuación 0
Comentarios:
If not, try flashing your IPhone in "DFU Mode".
- de
Añadir tu respuesta
Corey Griffiths estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 21
