MacBook waterdamaged does not turn on
Hi guys,
I spilled water on the keyboard of MacBook while trying to take out a charger from my backpack. (Two days ago)
-My MacBook's battery was dead before spilling water
- I had a keyboard cover, so thought the water didn't get into the MacBook. I quickly cleaned up the water on keyboard cover.
However, when I pressed few keys to check the Macbook, it didn't show me the battery and charger image thing it just showed before I spilled water.
So I dried about 12 hrs, and connected Macbook with a charger. The charger worked correctly, showing green and turned to orange as charging.
I then tried to turn on the Macbook by pressing few keys, but it didn't turn on. (Tried less than a min) Then, I quickly disconnected the charger, and let it dry a day.
Today, I opened up the Macbook and didn't see any water trace. However, one LSI has pink small three dots as picture shows. I pulled out the logic board, and found out that a LSI locating back of logic board turned red.
I used q-tips and alcohol to clean up the whole board just in case.
Do you guys see what might be wrong, and what should I do further before I assembe again?
Thank you in advance!!
Es esta una buena pregunta?
