Saltar al contenido principal
Tercera generación de iPad con Wi-Fi, lanzado el 16 de marzo de 2012. Número de modelo A1416. La reparación requiere calentamiento y palanca cuidadosa.
Preguntas 154 Ver todo
Slow Charging, 15% on 2 hours
Hi,
Im having an issue with an iPad 3.
- Already replace the dock connector, but the battery charges real slow, about 15% in 2 hours. Rested multiple flex connectors, issue persist.
Any one had encountered this issue?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
It's probably battery related. However, before replacing the battery, try a known-good original iPad charger and Lightning cable to eliminate that as a potential source of problems.
If you have confirmed that the charger and cable are good, the try to replace the battery, following this guide, to see if that solves the problem. Otherwise, it could be a logic board/charge circuit issue.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Robert G estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 137
