My Laptop won't charge the Battery nor Boot on it without AC adapter
Hello everyone, Hope you're doing great.
My problem is a little bit unusual (i guess)
My laptop won't boot on a perfectly working battery, and also won't charge it.
When i start my laptop on the AC adapter and connect (or the battery is already connected) the windows icone of the battery shows that my Laptop is on battery only (which is not)
This is a capture of my desktop (note that my Laptop is plugged with its AC adapter)
This is confusing , i tried many things to fix this problem (i changed the power port, and tested the battery and AC adapter) one thing i didn't try is a solution related to the Charging Circuit due to the lack of experience with circuits and also because they told me it may put an end to your and your Laptop's misery .
Please i just need an explanation to what's wrong, even if it's not fixable.
Thank you and peace upon you.
Es esta una buena pregunta?
you have a charging circuit issue.....the chip which switch between the adapter and the battery... It's some component around this chip or the chip itself who is the problem.
- de roger cranston
