Saltar al contenido principal
La única versión wi-fi del iPad Air de Apple, número de modelo A1474. Disponible en Space Gray o Silver, incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
Preguntas 299 Ver todo
Battery connector doesn't work
I have an iPad Air model A 1475, the battery doesn't charge any more. In the App Store in Argentina they diagnosed it and said the battery was ok, it is the the battery connector that is not working. Do you have a battery connector replacement for this model? Thank you!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
There is no standalone connector on the iPad air unfortunately, the connector is part of a cable directly soldered to the logic board. Unless you can find someone in your area who can do microsoldering, you should replace the board which would probably cost you as much as a second hand tablet. You can try blowing it with a compressed air can and clean it with alcohol and a tiny piece of cloth and tweezers in case it just about some debris and dirt stuck inside.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Greta Schormair estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 287
