Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4266 Ver todo
Battery replacement- Phone not turning on
Just replaced my battery
The phone is not turning on, though I can feel some heat while it is on charge.
My PC does recognize the device
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
No, nothing happened
And when I tried connecting my phone, it recognises it at first and then says an unknown arror occured, which suggests that it is not the screen.
I may just replace the logic board and see what happens
por
I just replaced my battery. It won't turn on. I plugged it in to charge and the apple lights up for 5 sec then goes off for five sec, repeating now. Any suggestions?
por
Agregar un comentario
1 Respuesta
Solución Elegida
You may have damaged the backlight circuit on the logic board if you disconnected the screen without disconnecting the battery first.
To be certain, shine a bright flashlight on the screen when you connect it to iTunes. If you see a dim image, then your backlight circuit is blown and will require a micro-soldering solution.
Fue útil esta respuesta?
Calificación 1
Comentarios:
por
When i place my hand on the circitry it is warm
por
Añadir tu respuesta
DochMcCrum10 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 48
