Saltar al contenido principal
La edición 2013 de la tableta Kindle Fire HD de 7" de Amazon. Una edición económica de la nueva línea Kindle, con una resolución de pantalla inferior a la del HDX y sin la cámara del modelo 2012. Lanzada el 2 de octubre de 2013.
My kindle makes sound, but the screen won't turn on
So my kindle fire powered off. I have charged it. I can tell its on because the kindle makes a chime when turning the volume up or down. THe kindle shows nothing, it looks like its off.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
5 comentarios
I tried doing this put it made a sound like
pppling and I’m worried about it.
WHAT SHOULD I DO?
- de
I turned on my tablet while charging and i heard a chime sound but i didn`t see anything on the screen
- de
Iv got sound but no picture
- de
Whenever I plug in my kindle it won't turn on I hear no chimes but when its plugged in and I hold down the power button to turn it on it makes a crack sound and doesn't turn on. It has cracks on it.
- de
I was playing on my computer but my kindle was on the next time I look the kindle looked off so I thought it died plugged in for 30 min. It chimes but the screen is not on. p.s. no damage whatsoever what do I do?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
There are two likely faults with three possible fixes.
The most likely fault is a crash, which could be resolved by holding down the power button until the screen turns back on.
If that does not work you may need to restart the device by pulling the battery. Which can be done by following the first two steps of this guide.
Kindle Fire HD 2013 Battery Replacement
The last option is a screen replacement, which can be completed by following this guide.
Kindle Fire HD 2013 Screen Replacement
I hope this helps,
Charlie
Imagen de Kindle Fire HD 2013 Battery
Guía
Dificultad:
Fácil
10 minutes
Imagen de Kindle Fire HD 2013 Screen
Guía
Dificultad:
Moderado
15 minutes
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
R E D estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 15,154
