Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
Preguntas 51 Ver todo
problem occurred while converting microsoft outlook 2010
hi guys, my problem is that I can't convert ost to pst , are there any thoughts about this ? I would be very grateful !
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
You can convert the Outlook OST to PST using some simple manual techniques. But, if you are not technically sound enough and feel difficulty in adopting the manual methods, you can go for a third-party software tool i.e. an OST to PST Converter. It is a simple method for this conversion.
You can refer to this: https://msoutlookhelp.com/
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
Todos somos Genios
1 Respuesta
Solución Elegida
Outlook Inbox Repair Tool (Scanpst.exe) is a utility that you can use in this case to repair your damaged archive.pst. It is highly recommended that you backup the damaged PST first as running the tool can irreparably damage the file.
• 1. Quit the application
• 2. Scanpst.exe is a hidden file so make sure that the 'Show hidden files and folders' setting is enabled in the folder options
• 3. Click Start | Search, or Find and type 'Scanpst.exe' in the Search box
• 4. Double-click to open the file and browse to the location of your damaged archive.pst
• 5. Click 'Start' to start the recovery process
• 6. Try to open the file in question again. The corruption problem should not exist.
or you can try to use pst repair - http://www.erepairoutlook.com/
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
matthew weatherholt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 2
Últimos 30 Días: 2
Todo El Tiempo: 63
