Saltar al contenido principal
Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4839 Ver todo
Silent Switch Becomes Tough when Screen is in place
Hi,
In the period that I have owned my phone, the silent button has had no issues until now. Recently, the switch will refuse to go into the loud position, and requires quite a bit of effort. However, it will still switch to silent with ease.
After some exploratory search in the phone, I found that when the screen is lifted away from the device, the silent switch will continue to work as per normal, and switch both ways with ease. It is only until the screen is clicked back into place that the problem persists.
I know this isn't a huge issue, but it would be nice for the silent switch to be in working order again.
If anyone has any ideas it would be greatly appreciated :) .
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Baterías para ordenadores portátiles
Un pequeño arreglo para un gran resultado.
Comprar Ahora
Comprar Ahora
1 Respuesta
Respuesta Más Útil
There is certainly something that is out of alignment. When you remove the screen, you will notice some metal tabs that protrude (they have screws to hold the LCD Heat Shield), look through this guide for reference.
The tab nearest the Mute button may be bent enough that it is causing friction or resistance.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Cheers! I’ll have a look and give this a go. I’ll let you know how it goes :)
por
So I've had a look at the heat shield. There are no tabs that come anywhere close to the mute button..
I also found that by pushing on the screen by the mute button, causes the silent button to stiffen up further?
por
Añadir tu respuesta
Harrison Hill estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 41
