What is the best tape or glue for rear glass and digitizers?
What is the best way to reattach the digitizer and rear glass on samsung galaxy devices S5 and up?
Es esta una buena pregunta?
I use ZHANLIDA B-7000... its glue... not tape...
Fue útil esta respuesta?
is this permanent though? if i have to replace a part on phone again while i be able to fix again?
its really strong glue, like chemopren base... but with isopropanol posible remove
perfect thank you i will try this!
usually 3m double side tape
do you have a link to where i can buy some that doesn't cause the screen to lift
Kristina, here is an adhesive made for the s5. It is only $5.99 and you can order it right here. Enter the Item Code below in the search bar and you can check it out. I hope this helps. Please let me know, Thanks, John
Galaxy S5 Touch Screen Adhesive
Item code: IF236-043-1
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 298
