Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
La línea de laptops PowerBook de Apple fue planeada para los usuarios profesionales. La línea de PowerBook incluye el PowerBook 100, Duo, 500, y la Series 5300; el PowerBook 1400, 2400, 3400; el PowerBook G3, G4 Titanium, y G4 Aluminum.
Preguntas 1318 Ver todo
Fans force air when turning on PBG4
Watching the Audi Channel one night the PB screen went black (that was before it stuttering on the internet connection).
When turning back on, the fans just keep blowing air and there is no display. Screen is black. No beeps.
This is 15" PBG4 - had for a bout 4yrs. Could the screen inverter have gone or is this a logic board issue.
Help appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
2 Respuestas
Respuesta Más Útil
Check the RAM of the computer try re-seating it, and see if that works. If not, you may have a much more serious problem, you may want to look into putting a shim on the CPU, and GPU, if that solves the problem, tell me, and i'll go into more detail on a permenant repair procedure
Fue útil esta respuesta?
Puntuación 1
Comentarios:
Not sure I understand what you mean by "shim" - can you explain?
- de
A shim is a non-conducting spacer between the case and the chip to force it into contact with the logic board.
- de
It's not the inverter, if that failed it would still boot normally, just with a black screen. As it is ramping the fans up that is the logic board entering CPU protection as it isn't booting, but as the screen is staying black, would say it is due to a failure on the logic board.
Puntuación 0
Comentarios:
I'm guessing it's the logic board, but want to try some things first. I do get an intermittent chime from the PB, but then it goes silent and just blows out air from the fans
- de
Añadir tu respuesta
Reboot estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 946
