Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1360 Ver todo
Problem with restart loop
Hi
I hope all is well with you
I have an iPhone 6plus which is stack in restart loop which restarts after Apple logo appeears.
I have changed the displaty, batteri and charging flex and even restore ios11 via iTunes but it did not help and I still got the problem and somtimes it comes up to screen lock and when i enter the code, again it goes to restart loop.
Do u have any solution for this sort of problem?
Want to hear all types of help from you :)
Sincerely
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
1 Respuesta
Solución Elegida
Assuming that the replacement parts you used are in good working condition, you have pretty much eliminated the main modular elements that could be causing the boot loop. You could also try to disconnect the cameras and sensors just to see if that makes a difference but the issue is most likely coming from the logic board itself.
Has your phone been dropped, repaired (prior to this) or came into contact with water?
Fue útil esta respuesta?
Calificación 2
Comentarios:
Thansk for your answer @refectio
In fact I dropped it many times and I have thought the main boara has some serious problem.
I may try to using soldering in case to fix the problem.
por
Añadir tu respuesta
Habiballah Hezarehee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 84
