Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1364 Ver todo
Having problems with screen replacement
Having trouble re installing the front facing camera assembly, I was told to buy the plastic holders for the camera and sensor, I am not sure where to put the sensor holder and I can’t seem to make it all fit without the actual assembly partially blocking off the slot where to earpiece clips in. Any ideas?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Your front camera plastic holder is not in the correct orientation.
Rotate it 90°C clockwize and it will fit the front camera no problem. If you want you can check matching of the notches / indents of the front camera itself to the plastic gasket.
Use this image for reference:
https://d3nevzfk7ii3be.cloudfront.net/ig...
The two indents should be top and bottom and not left and right to fit the camera.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
try and follow the guide to see whats going wrong for you.
Reemplazo de cable de sensor y cámara frontal del iPhone 7
Puntuación 1
Añadir tu respuesta
Ben Rowson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 49
