The HTC Desire 816 features a 5.5-inch display with a 1280x720 resolution, 13 mp rear facing camera and HTC BoomSound.
Preguntas 66 Ver todo
The device doesn't boot without a charger and turn off when heavy use.
Hi all,
The device was functioning properly since it turned off suddenly, now it boots at HTC logo then turned off and doesn't boot completely until I plug it with the charger or any power source.
I noticed that if i enabled the power extreme save mode and unplug the charger it keeps running, until I disable the power save mode and launch a (heavy to CPU) app such as Facebook it turns off again..
So is this could a battery failure or a system issue?
Many thanks in advance.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
I liked that HTC, but the battery was a dud. Sorry.
Shut off everything, WiFi, GPS, Btooth, wallpaper, everything you can find running. Check battery power. Now, run it down till battery-alert message pops up. Power it completely OFF. Leave it on the charger all night. By morning, it will have its highest power level. Leave everything OFF, until your new battery is installed.
por
Yes, that's true.. extreme power save does that (shutting off everything) and it keeps running with the basic functions.. I like it too, but as an old phone I hope to find a new battery for it.
Thank you.
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
1 Respuesta
Solución Elegida
Yeah that sounds like battery needs to be replaced.
Fue útil esta respuesta?
Calificación 2
Comentarios:
A new battery solved the problem, thank you!.
por
Añadir tu respuesta
William - estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 68
