Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Black Screen After Screen Repair
I have just fixed an iPhone 6's screen for a Cutomer. And the screen is black. It works because iTunes recognises it.
Tried the old screen and also another screen and none of the 3 screens work.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Solución Elegida
You may have blown the backlight circuit on the logic board. To be certain, shine a bright light on the screen after you connect it to an iTunes enabled computer. If you see a dim image, then the backlight circuit is damaged. This will require a micro-soldering repair.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
That's the thing, the display shows nothing! Yet iTunes recognises the phone. I have no idea what the issue could be.
- de
Then you will need to look at the LCM Driver circuit (Chestnut).
- de
is there image and no backlight ?
Puntuación 1
1 comentario:
The backlight doesn't work either
- de
Take Diode Mode readings of the FPC's and compare to 1st image, check Filters for continuity...For backlight, pay attention to image 2, and for image, you can start with 3 - 5, but may also find LCM Reset, Photon alive, etc while looking through diode mode readings if off...
Puntuación 1
sounds like you blew the backlight 99% of the time that happens because the battery was not disconnected during the repair
Puntuación 0
4 comentarios:
Oh crap! How do I fix that?
- de
you have to change the filter are you good with microsoldering?
- de
I'm not good with it no. I don't even have the right equipment
- de
where are you located? check shops around you or you can just send it in
- de
Añadir tu respuesta
Benjamin Poli estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 123
