6s hex nut standoff screw
The repair for my 6s requires removing the 1 hex nut standoff screw.
Is it possible/easy to remove this without the exact tool? It seems this tool isn't included in most tool kits.
Thanks!
Es esta una buena pregunta?
Thanks!
Some robust tweezers or needle-nose pliers should do the trick, the standoff is not very tightly secured. That said, using anything other than a proper driver could expose you to collateral damage so be extremely careful trying to remove it.
If you plan on doing this more than once, you should consider getting a driver before you do the repair.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 949
