Saltar al contenido principal
Modelo: Serie HX9300 La serie DiamondClean de Philps Sonicare puede identificarse por su número de familia de modelo: HX9300. Todos los modelos HX93xx son el mismo cepillo de dientes. El tercer y cuarto número determina el contenido de la caja. Los números después de la barra (/) determinan el color del mango.
Preguntas 11 Ver todo
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I have probably a similar issue. Who can find and change a battery here?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
Fue útil esta respuesta?
Puntuación 3
I'm having the same problem. Have you fixed it?
Thanks!
Puntuación 1
2 comentarios:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
- de
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
- de
Añadir tu respuesta
swat1230 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,211
