How do reattach a replacement Series 2 LCD flex ribbon cable?
I have a replacement iWatch Series 2 LCD Flex Ribbon Cable. How does it attach to the circuit board. Does the Flex Ribbon have an adhesive backing?
Es esta una buena pregunta?
Sorry to say the cable assembly is micro soldered to the SIP, it is not really replaceable as you can see here:
You are likely to pull of the solder pads from the SIP just trying to lift the old cable.
Fue útil esta respuesta?
According to one of our teardowns at iFixIt, the LCD is connected using ZIF connectors, which stands for Zero Insertion Force, meaning you can insert the cable with very little force (Citation from wikipedia: "The two sliding parts of the connector are then pushed together, causing it to grip the wires").
So no need to worry about any locking mechanism for the cables.
If you mean coming directly from the SiP, those I don't know of any replacing method or locking mechanism
I do mean connecting the Flex Ribbon cable to the SiP.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 948
