Cannot update to High Sierra
I just replaced the logic board and i could only install OS 10.8.5
High sierra is refusing to install. Is it due to firmware issue. What should i do
Es esta una buena pregunta?
If you replaced logic board you probably need set up correct date:
https://bensmann.no/changing-system-date...
after should be everything OK.
Fue útil esta respuesta?
Thanks, It is already showing the correct time and date
Can you give us the exact error message, that might give as a better clue here.
Also have you tried running Disk Utilities First Aid function to check your drive.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 53
