Update the iPhone 6s plus loudspeaker to another newer apple like 8
hello its possible to replace the iphone 6s plus loudspeaker to another loudspeakr like the iphone 8
behind the i8 loudspeaker are louder?
thanks
Es esta una buena pregunta?
thanks
hypothetically, you could do it by jumping the leads to the traces under the device with some thin wires.
they are not designed to be interchanged between the models modularily, so you will need a solderhing skillset to do this.
Please keep in mind, i have never personally done this, as custom modification work is not allowed at our franchise, so i will be unable to assist you if you run into trouble with the procedure. there could be issues with Voltage ratings, and the like.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 44
