Saltar al contenido principal
The Acer Aspire E 14 Touch can be identified by its model number: E5-471-5456. The device was released in late 2014 and has a 14 inch HD LED-backlit TFT LCD display, a NVIDIA GeForce 940M GPU with 2GB DDR3 VRAM,  as well as an intel core i5 processor with 2.2GHz.
Preguntas 4 Ver todo
acer aspire e5 471-35sl no power
my laptop acer aspire e5-471-35sl bios flash and now power is not open .not charging
Contestar esta pregunta I have this problem too
Puntuación 0
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
First of all, try removing the battery and turning it on with only the powersupply plugged in.
If that doesn't work try to insert the powersupply and wiggle it a bit, if it feels like the part that the powersupply is plugged into (the dc connector) is loose or follows the power plug without resistance to the wiggle, it will probably need to be replaced or resoldered onto the motherboard.
If neither is an issue you might have to open up the laptop and take out any removable hardware and periodically try to power it on. if you get to a barebones motherboard with not poweron then it is probably the laptops motherboard that is defective.
¿Ha sido útil esta respuesta?
Puntuación 0
Add your answer
ko latt will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
Global: 198
