Saltar al contenido principal
Información y guías de reparación del iPhone 8 que salió a la venta el 22 de septiembre de 2017. Modelo: A1863, A1905
Preguntas 873 Ver todo
iPhone 8 not "showing"a charge after the replacement of LCD?
The LCD was replaced. Now the phone is actually charging but no showing the charge. Everything is working. It shows 1% but it actually is charged. Now, it does power on and off on its own? Left it unplugged for two days. It was charged when I came back to check on the process but still showing 1%. Any thoughts?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
5 Respuestas
was the battery disconnected during the repair and reconnected properly post repair?
Fue útil esta respuesta?
Puntuación 0
Same here.. seems to be related to iPhone 8 & IOS 11.3..,
Michelle what iOS are you using? 11.3 perhaps?
Puntuación 0
If your battery is connected correctly as it should be then its related to IOS 11.3 software issues
Puntuación 0
Would not be the first problem iphone 8 has with replacement screens on ios 11.3, so could be the ios problem
Puntuación 0
Hello, i have this problem too... i change lcd for some OEM lcd and not work touch, now i make update 11.3.1 and touch work... but battery is still 0% and not showing the charging bold... when i connect to charger come first few seconds +/- 1100mA, after strarting OS come down on 200-380mA.... i inspect the board and like 2mm from battery connector missing one small part looks like capacitor etc.... i think this is the ptoblem.... can you tell me some good man what is the part? :)
Puntuación 0
Añadir tu respuesta
7michele estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 218
