Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1361 Ver todo
How to properly clean dirty speaker grill the top one and the bottom s
When playing something using the phone volume, it’s low and barely hear them. Tried cleaning the top speaker grill with alcohol swabs it helps a little but don’t know how to clean the bottom speaker.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Properly cleaning the top and bottom, two methods.
Basic way, use a anti-static brush, some use a toothbrush but I always take the safe approach, and gently brush the grills. Do not dig the bristles into the grill, so use a swiping motion.
Deep Cleaning, open device, pull speaker and mic component out, use compressed air to blow from inside out, brush if needed.
Keep in mind that if you're going to open the device you need to be cautious with the gold contacts and electric static discharge on the device. Mishandling can lead to improper functioning of the device. Follow the examples on Ifixit for dissembling the unit.
Do note that Apple has some strict guidelines about "tempering" with the device. If something were to go wrong it may void out any warranty services.
Good Luck
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
BenSihte estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 3,920
