Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2089 Ver todo
iPhone 6S No Service but SIM can be read and Modem Firmware is visible
I don't think it's a problem with the SIM reader. I tried a working Verizon one and it called fine when I turned on WiFi Calling, but it still showed Searching and then No Service. If it was a baseband IC chip problem, wouldn't the Modem Firmware be unavailable? Earlier today, I turned off Airplane Mode for whatever reason since I always keep it on and the Verizon text actually showed up with about 3 bars and went back down to No Service within a minute; I've never seen it do that before.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Android
A new screen or battery is one kit away.
Comprar Ahora
Comprar Ahora
3 Respuestas
No service/intermittent service is an internal problem that should be replaced by Apple. There could be a baseband chip issue - you may send the device to a micro soldering establishment.
Fue útil esta respuesta?
Calificación 0
Apple can fix it if you send it in or take it to a Apple store for repair. If it’s in warranty they’ll fix it for free, if not the price varies.
Calificación 0
Has your issue been fixed? I have exactly the same issue. I think only the Antenna and not a IC is broken...
Calificación 0
Comentarios:
nope. i suspected there was an antenna problem too, but there was no way to test. there are ebay services that will fix "no service" for you for ~$50. search "no service 6s". spending that much now, i don't think you would add to the value of your phone any more than $50, but it would make it more likely to sell. so it might make sense to fix it
por
Thank you for your answer! I ordered a new antenna and if it fixed my issue i will report back. :)
por
Añadir tu respuesta
michael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 30
Todo El Tiempo: 1,606
