Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Un ordenador personal que reside en una ubicación con sus componentes principales dentro de una caja separada de los periféricos de terceros necesarios para la operación, como un ratón, teclado y monitor.
Preguntas 259 Ver todo
Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
Es esta una buena pregunta?
Puntuación 0
Comentarios:
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
- de
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
- de
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
- de
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
- de
Agregar un comentario
2 Respuestas
Solución Elegida
The broadcast Pix slate G 1000 is not a typical computer. This is a highly customized machine with proprietary hardware for broadcast television video. I suggest posting on their forum for an answer.
Fue útil esta respuesta?
Puntuación 1
Comentarios:
i will post there
- de
Respuesta Más Útil
If you just Google for your brand of motherboard suffixed by "beep codes" you may well find the answer.
Puntuación 1
Comentarios:
I can't it's a special motherboard made by the computer company that is the same one that made the computer.( The pc is a switcher)
- de
Añadir tu respuesta
McOfficialPlayYT estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 97
