Saltar al contenido principal
Modelo A1419 / EMC 2806 / Finales de 2014 o mediados de 2015. 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 finales de 2015 / 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (iMac17,1) Todo con pantallas Retina 5K
Preguntas 566 Ver todo
Is it possible to install an SSPOLARIS SSD drive in my 27" iMac?
I'm thinking about upgrading my late-2015 iMac with an SSD.
Currently it only has a 1TB HDD, I saw that apple now has these new SSPOLARIS drives which are way faster than the SSDs that were shipped with my iMac's generation.
I have the following iMac:
Apple Model No: A1419 (EMC 2834) Model ID: iMac17,1
I noticed that the SSPOLARIS drive has a slightly different form-factor but has the same socket.
From a compatibility standpoint, is it possible to install this SSPOLARIS in my iMac?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
One of these is your system: iMac17,1
- de
Yes, the iMac "Core i5" 3.2 27-Inch (5K, Late 2015)
- de
Agregar un comentario
1 Respuesta
Solución Elegida
The speed difference has a lot to do with the width of the PCI lanes the newer systems support. Your system only has a PCIe 3.0 x2 SSD where as the newer Mid 2017 27" iMac's (iMac18,3) have a PCIe 3.0 x4 SSD.
Reference: The Ultimate Guide to Apple’s Proprietary SSDs. Sadly Cody has incomplete information on the iMac's and his section on the iMac (Late 2015) is a bit confusing.
You'll need to make sure you've got Sierra installed as it applies a firmware update. That should do it and then add in your new Apple blade SSD BeetsTech - Apple Solid State Drive (2TB) or if the 2TB drive is a bit to much for your pocket here's the 1 TB drive: BeetsTech - Apple Solid State Drive (1TB)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Randy Alvin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 915
