Saltar al contenido principal
Guías de reparación y solución de problemas para las laptops Acer Predator de 17,3", un grupo de computadoras para juegos de gama alta de Acer. Estas laptops cuentan con una pantalla de 17,3", GPU dedicada y una bahía modular para una unidad óptica o un módulo de enfriamiento.
Preguntas 16 Ver todo
Can I , and is it safe to add an on/off switch to my laptop battery?
So the main idea here is that i get better performance whilst plugged in.
I like gaming so I play a lot. I usually start playing when the battery is low so i can play and charge , thinking it's better for the battery to be used (charged and discharged) .
After playing for a while the battery gets full , and I want to keep playing with the same performance. So I came up with the idea to add a switch to the cables connecting the battery wires with the motherboard. So I can stop using the battery when it hits 100% and continue playing plugged in. And after finishing I would turn the switch on, connecting the battery with the motherboard and then remove the plug and continue browsing using the battery. But am afraid to try because i just got this laptop.
Es esta una buena pregunta?
Puntuación 1
1 comentario
Hi i want to do the same with my laptop. How have you managed to do it? What kind of switch or circuit have you used? Thanks in advance.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Sounds like a good idea but i would be extremely careful to not short anything i wouldnt attempt this is your are an amateur at soldering and such but if you are experiened id go for it!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Zero Trace estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 461
