Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA / 64 or 256 GB / gold, silver, and space gray.
Preguntas 70 Ver todo
Touch not working after repair (PSA)
I use very high quality aftermarket parts from a supplier who backs them with a lifetime warranty. The 3d functions almost identical and the color and brightness are almost spot on to OEM. The main reason I use these is because most customers care about cost and nothing more. Atleast, that is my experience ( I fix around 40 phones a month for extra income). Overall, I have very little issues with their screens. I said all that to say this/ask a question.
Today, I attempted to repair an iPhone 8 plus. I have fixed two recently with no problems. After testing the screen before snapping it in, all was well. After installing it all the way the touch functioned fine, but after I locked and unlocked the phone, the touch died. I tried reseating cables, pulling the screen out to sit on cardboard incase of grounding out etc. Nothing worked. I tried another 8 plus screen from a different supplier. This time the touch never worked. I started to panic, because I believed I had blown a fuse or cap that controls the touch. I tested the broken original screen and it worked fine. I tried two more screens with similar results to the first attempt. It worked fine, but after locking and unlocking the phone the touch wouldn't work.
I gave up, since I was out of screens and gave the phone back broken, but working.
Now here's what worries me. I noticed the phone was updated to iOS 11.3 yesterday. I just successfully repaired an iPhone 8 plus yesterday from the same batch of screens. I confirmed with the customer that she had not updated to iOS 11.3. What are the chances that I had 4 bad screens exhibit the same behavior from two suppliers? Im hoping this isn't a glitch in iOS 11.3 and if it is, will it affect screens across all models? Yes, I know it's best to choose original repair parts or at least original refurbished parts, but customers don't want to pay 50 to 60 bucks more on average for a repair even after I explain the differences.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
5 Respuestas
Solución Elegida
FYI. We buy some parts from this vendor, but not iPhone screens. However this is probably what you are looking for.....
Fue útil esta respuesta?
Calificación 1
Comentarios:
Great find. Thanks.
por
I predict 11.3.1 will be released soon.
por
Respuesta Más Útil
Honestly hard to tell because I haven't gotten clients wanting to repair iPhone 8 yet.
I've only tried one iPhone 8 screen and closed it touch appeared to still work but this was only for data recovery purposes.
Guessing you've done heaps of iPhone 7 and 7 plus right? Pretty much same procedure to that one.
Calificación 1
Comentarios:
Yes, I've done a lot of 7 and 7 plus screens. It's very strange. I hoping it's not iOS that's the problem.
por
I think the signing servers are still active for 11.2.6.
Why don't you download the full firmware for 11.2.6 and see if the phone works properly if you downgrade. Better work quick while they are still signing.
por
Yeah 11.3 and 11.2.6 are currently still being signed by apple servers at this moment.
por
so this is a issue with the new ios, downgrading it will make a aftermarket screen work. guess its going to mean finding a screen disto that has premium quality screens or waiting to see if they make a patch for it.
Calificación 0
I had my iPhone 8+ screen replaced a while ago, which resulted in a lack of audio from earpiece. After getting that replaced, phone was just fine. Now, I just installed a software upgrade (whatever newest one is. 11.3?) and no touch response whatsoever even with umpteen hard resets. Can't reset through iTunes because the passcode is activated and I can't enter it. What can I do? I have no idea how to revert to my old iOS and I have no idea what's going on. Do I have to go to Apple or can the guy who replaced the screen initially fix this for me? Also, I know you have to turn Find my iPhone off for them to provide support, but I can't even do that! Help! I NEED my phone.
Calificación 0
Comentarios:
Get the person who fixed your phone to downgrade iOS or install an original apple screen. The later may cost you, because the cost of an original screen usually averages $90.
por
After IOS 12 upgrade the screen on my iphone 7plus was completely frozen. Resetting phone a number of times produced zero results. The only thing that worked for me was to put the phone into DFU mode (Hold power and Volume down button simultaneously untill DFU mode is entered). Then plug phone into Itunes and click restore button but only allow restore process to continue for a few seconds. shut down itunes, unplug cable to phone and hold power and volume button until logo appears. Phone should now work.
Calificación 0
Añadir tu respuesta
Brian Wood estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 33
Últimos 7 Días: 198
Últimos 30 Días: 687
Todo El Tiempo: 4,610
