Won't turn on for some reason
I'm having trouble with my Pokémon edition new 2ds XL it won't turn on. Even the blue light or charging light won't turn on. Help me pls
Es esta una buena pregunta?
When did it stopped working? By any chance you have used different chargers? It might be fuse on logic board
Fue útil esta respuesta?
most likely your battery, make sure the charge cable has no rips or exposed wire and keep it plugged in for 2 hours and then try powering on. if still no response let us know please.
This is the same issue I am having with my 2DS XL. I had the exact same problem with my DSi XL, and it was the upper LCD screen ribbon cable. It was damaged, and after replacing the top screen, it worked again.
I am waiting on parts to arrive, but I am attempting to replace my upper screen soon. I will report back once I replace it.
Because of the pop sound and shutting off happening in the exact same way on both systems, I am confident that it is the top screen to resolve your issue.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 3,914
Mine has a similar issue but my thing is that the lights turn on but when I press the on button the screen remains black and after roughly 3 seconds it turns off and there is a pop sound played through the speakers when it turns off
- de GlitchytheGlitch
I’m having this exact issue did you find a resolution @GlitchytheGlitch
- de Jake mitchell
Yep. Verbatim. Exact same problem.
- de Kyle
I'm late, but this means something inside is broken @GlitchytheGlitch. You should take it apart and see if something is unplugged. then replacee the battery.
- de boimydudeman
if it pops it has to do with the screens . it could be the top or bottom that isn´t working .
- de Heriberto Presencion
