El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3634 Ver todo
boot loop after screen replacement (both old and new screen - no BSOD)
Hi there,
I replaced the screen of my iphone 5s and when testing it before closing the case finally, it's stuck in boot loop (without blue screen, just eternally stuck in apple logo and restarting, can't even turn it off). The same problem persists when I reattach the previously working screen (just the screen and digitiser without the camera, audio components and home button that are transferred to the new screen).
I can get it in DFU mode, but can't update or restore the phone (at some point in the process error 9 appears and stops the process).
I have forgotten to disconnect the battery when replacing the screen. Not sure if replacing the screen and changing the parts without disconnecting the battery might have fried some hardware component in the process or whether there might be a different reason for it getting stuck in boot loop?
I have taken the screws out of the EMI shield and made sure that all the screws with the right length are inserted in the second attempt. Don't think that it's screw damage though as this would result in a blue screen, no?
Any tips what I might be able to do to get it to work again?
Thanks so much for your help,
Janosch
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Error 9 on the iPhone 5S is usually related to long screw damage. Take a close look again, this time under magnification (and good lighting) within the standoffs of the LCD bracket. Look for damage similar to what you see on this page.
If this is what's causing your problem, it will require a micro-soldering repair. Long-Screw Damage is a fairly difficult repair and it may not be economically viable for the iPhone 5S anymore, depending on your location.
Fue útil esta respuesta?
Calificación 2
Mmh okay, thank you! I live in the UK. Any idea who might be performing micro-soldering repairs over here and how much it might cost?
Calificación 0
Añadir tu respuesta
Janosch estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 36
