Saltar al contenido principal
Una colección de guías y soporte para reparación de lavadoras
Preguntas 3478 Ver todo
LG front loader won't drain
I have an LG front loader that won't drain. I can hear it buzzing like the drain motor is trying to drain, then I get an "OE" error ("no drain" issue), and it stops without spinning.
So, I removed wet clothes, drained the washer manually and checked the drain filter/trap (it was clear). I then turned on the drain/spin cycle with an empty load and it worked (started spinning).
I put the very wet (soaking) clothes back in, started the drain/spin cycle and I hear the drain motor trying to drain and then get the OE error again and no spinning.
I tried a master reset as described in LG WASHER won't drain or spin. No joy.
Any suggestions on what to try next. Thank you!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Solución Elegida
So, I called in the professionals - he said it was a problem with the pump impeller. Cost to fix is $311.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
What is the reason our clothes sour after washing in cold water
- de
Do I need a trap on my drain
- de
The water sits in the pump and sleeps through into the impellers trapping stagnant water so I would say you need a new pump
- de
pump out of my washer
Puntuación 0
pump out of washer
Puntuación 0
Añadir tu respuesta
bocotim estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 22
Todo El Tiempo: 14,895
