My rear camera takes blurry pic and it seem like its shaking
Do i need to replace my camera? It takes blurry picture and it seems like the camera is shaking
Es esta una buena pregunta?
Yes , It need replacement. Try to get an original/genuine replacement
Fue útil esta respuesta?
you can also get a back cover lenses replacement this little round and a battery for it and make it run like new
The stabilizer needs to be replaced but Apple may do it for free. Here's the program:
Apple is unwilling to admit a coding glitch present in recent updates. The image stabilization built into iphone cameras works by pulsing minute amounts of current to a ring of very tiny magnets surrounding a gimbal in which the camera lens is mounted. This is done in instantaneous direct opposition to even the smallest movements. A coding error causes these magnets to pulse out of synch with the movements.
A very simple and effective fix is to get a tiny neo magnet (5/16” dia. or less) and hold it against the upper right hand corner of the face of the phone. Open the camera app and move the magnet slightly until the shaking stops. then take a tiny drop of super glue and affix the magnet to the phone in this spot (it’s better if you use a screen protector). The problem will be corrected, although your image stabilization may be reduced, and your photos will be sharp and clean.
This beats a $200 camera replacement at the Apple Store.
Wow! This worked for me!! I have an iPhone 7 and my camera was taking blurry pics. I recently changed my battery too and want to use to phone for atleast a year or two. Thanks to you my problem is solved
Just watch the video it will help you
How much do they pay for a shaking camera 6s plus
I had this problem too. Tossed my phone on my floor. Thought it landed on my blanket. Picked it up and next thing i knew the camera was shaking. It took a lot of trial and error and about 3 hours but I eventually got it fixed by banging it up against my hand. Almost broke it but now it works like new. It only starts when I do that again. Im gonna go get it fixed at Apple sometime within the next couple of days.
Ultimas 24 horas: 2
Ultimos 7 días: 34
Ultimos 30 días: 147
Todo El Tiempo: 19,608
did you drop it recently?
- de Aiden
