Digitizer only replacement possible?
Is it possible to separate the LCD from the digitizer on a Surface Pro 4 tablet so I can just replace the glass, or does the LCD need to be replaced as well?
Es esta una buena pregunta?
The fourth-generation Surface Pro tablet, released October 26th, 2015.
Hey Jay,
It appears as though it is possible, though it is not feasible. You would have to buy re-laminating/refurbishing equipment (expensive!). This is due to the fact that the digitizer is secured to the lcd with a film adhesive that is difficult to remove. I would just recommend purchasing a new digitizer lcd assembly. You can replace it with this guide.
Hope this helps,
-Tanner
Comentarios:
is this type of screen common/becoming common? Because if it is I might need to invest in that sort of machinery anyways
- de Jay
It is very common (especially in iPhones). However, I'm not actually sure if there are any consumer made laminators available for Surfaces. I know they are avalibe for iPhones (here's a good one - http://www.rewatechnology.com/solution/r...). But, this would cost you about $3,000+, so I wouldn't reccomend it unless you are looking to refurbish screens.
-Tanner
- de [deleted]
thanks for the advice!
- de Jay
Ultimas 24 horas: 3
Ultimos 7 días: 26
Ultimos 30 días: 79
Todo El Tiempo: 2,143
