Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2110 Ver todo
LCD Screen Flex Cable does not fit in connector
Hey guys,
This is about the third time this has happened to me with an iPhone 6s screen replacement from iFixit. The LCD Connector's pins seem far larger than the original screen so it doesn't go into the socket well it seems as I cannot get the device to boot. Putting in the old screen results in a good boot so the phone is fine. Has this happened to anyone?
Update (03/22/2018)
The original connector is the bottom one of these:
The new connector from the iFixit part is this one:
If you look closely the contacts are larger and have a different shape, is this a defect?
Contestar esta pregunta I have this problem too
Puntuación 0
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
Ive had many that were a pain to line up just perfectly. But if that is the right screen for the phone, It should fit. I let the connector where I think it should go and gently slide the screen connector around every so slightly until I feel them line up. Then a good push down should snap it in.
Good luck
Puntuación 0
Add your answer
mbarthet3 will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
Global: 41
