Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 985 Ver todo
Proximity sensor doesn't work but camera work.
So, I have recently bought a iPhone 7, and it seems that the screen is not the original one. The problem is that the front camera works great but the proximity sensor not. I have iOS 11 and in the preferences the option to disable or enable the automatic brightness of the screen it's gone... It's possible that the proximity sensors are broken and the device does not present that option because of that ?
Thanks for helping! I have attached a print screen from the iPhone.
Regards
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
Todos somos Genios
1 Respuesta
Solución Elegida
The proximity sensor has nothing to do with the auto-brightness feature. It is used to disable the screen when you make a call; it will detect that the phone is pressed against your cheek and close the display so that the digitizer doesn't register any touching.
During the previous repair, it is possible that the prox sensor was incorrectly positioned or possibly even damaged. It is part of the FCAM flex. You can check that yourself via this guide.
As for the auto-brightness, that function was moved to the Settings/General/Accessibility/Display Accomodations menu.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Ok ok , proximity sensor definitely don't work, because in calls the screen remain on! But the weird thing is that in Settings/General/Accessibility/Display Accomodations menu the automatic brightness option does not appear ... My print is in Portuguese sorry about that but is in that menu. It is possible that the flex are broken? And iPhone doesn't recognize the sensor so the option in menu is unavailable ? Regards
por
Añadir tu respuesta
julioficabem estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 5
Últimos 30 Días: 41
Todo El Tiempo: 292
